Holly Hill, SC | You said speed is good, so therefor distance needed to calculate area should be good. Area will only count when seed is flowing and reading on the monitor. You have to work on getting a seed flow reading on the monitor first. Is the harness plugged in correctly between the cab and planter? (We use an older 6 row planter and 250 monitor with the Amp plug broken which allows it to get plugged together incorrectly) Typically this problem would only show speed and area and no row failures. If you send a brush or stick down the seed tube over the sensor are you getting any response from the monitor? | |
