Search Forums | Classifieds (88) | Skins | Language
FMX Field Iq ISSUES
Bjp9130
Posted 5/8/2024 20:06 (#10733668)
Subject: FMX Field Iq ISSUES
NW WI
We have had this setup for a number of years and has run fine on a couple tractors. Here is the setup.
FMX to fiq master and 12 switch box
Can goes to a Powell connector and meets up with power off of relays from the battery.
Extension cables then go back to 2 rate and section control modules and a seed monitoring module.
Second rate is for fertilizer.
What we are having trouble with is the master box and 12 switch box randomly connecting and disconnecting and cutting out the planting. Ran great for the first 60 acres and now I can’t keep it going. This tractor for some reason has never wanted a can terminator attached where another will. This is the first time this has happened. Any ideas would be appreciated.
