Posted 5/9/2024 06:23 (#10734057 - in reply to #10733895) Subject: RE: How to get a trimble 250 apart
NW IL
Take a look at attached picture. Note the sticker at the bottom (warranty void if label moved). There is a screw under this sticker that is commonly forgot about. In total I think there are 9 screws you need to remove. Once all 9 are removed it should pop apart.
