Posted 5/3/2024 12:13 (#10727327 - in reply to #10727294) Subject: RE: Trimble ez guide autopilot
NW KS
If the navII box has been gone through try the the steering angle sensor. The issues you are having is almost always cause by either the angle sensor or the navII. You might check the wiring going to steering angle sensor too. If it is using an auto sense angle sensor the wiring going to the sensor ends up being a wear item.
